A/C heater vacuum solenoid
Old Jul 17, 2007 | 06:50 PM
bill9iron's Avatar
Default A/C heater vacuum solenoid
I have a 1998 Explorer Sport and found a vacuum solenoid leaking antifreeze inside the engine compartment. What is the vacuum solenoid that bypasses the heater core called when the A/C is on? It doesn't show up anywhere in the Haynes repair manual.
Old Jul 17, 2007 | 09:49 PM
Default RE: A/C heater vacuum solenoid
#2.. Water/Coolant Diverter valve, Water/Coolant control valve.. Depends on who you ask
[IMG]local://upfiles/6756/D40C361DE1AD4D3DBE5D4B8AF6F58291.gif[/IMG]
Old Jul 18, 2007 | 07:28 PM
bill9iron's Avatar
Or also I found out it was the "heater control valve". Thought I had a head gasket leak due to a small amount of antifreeze consumed over a month. Saw it dripping by accident as I was testing A/C fill. This should be an easy fix. Thanks for your response hayapower.
nflz32
May 10, 2007 02:35 AM
jdm
Feb 26, 2006 08:38 PM
1Harley1
Jan 24, 2006 05:20 PM
shelleyrick
Dec 10, 2005 06:29 PM
redtide265
Jun 29, 2005 04:48 PM
