Check Engine Light
Old Sep 12, 2005 | 02:07 PM
mikew's Avatar
Default Check Engine Light
Check Engine light is on it is red everything seems to be running ok. late for an oil change could this be the cause?
Thanks
Old Sep 12, 2005 | 02:31 PM
cctxfish's Avatar
Default RE: Check Engine Light
[sm=feedback.gif] year, engine, codes ?????
Old Sep 16, 2005 | 05:41 PM
Sabretooth's Avatar
It is unlikely that just the oilchange would be the cause of the Check Engine light, but as cctxfish says, [sm=feedback.gif]
Old Sep 20, 2005 | 12:03 PM
mikew's Avatar
It is yellow not red. is this emissions? 1997 i think 4.0 came on right after car was inspected. what is danger of continue to drive? how can i reset codes? disconnect battery?
thanks
Old Sep 23, 2005 | 05:45 PM
Sabretooth's Avatar
well, first thing you have to do is go to somewhere like Autozone or Pep Boys or something along those lines because they will hook up a computer to your car and it will give them a code which will tell you what is wrong...depending on the problem, they can also reset it right then and there...otherwise, it may be a problem with a part, which they will be able to tell you, and you can get it all fixed up...
Old Sep 29, 2005 | 03:57 AM
jbwilli's Avatar
No. Something else is going on. Go to Autozone and they will read the code causing the light to come on for free!
93redxlt
Mar 18, 2010 04:44 PM
allensimpson
Jan 10, 2008 09:40 PM
farris1307
Sep 9, 2005 04:59 PM
basketbjones
Aug 30, 2005 10:16 AM
bluemq1
May 16, 2005 08:06 PM
