Fuel Filter holder exchange needed
Old May 17, 2016 | 07:56 AM
Two fords's Avatar
Default Fuel Filter holder exchange needed
Per my alias, I have two Xs now the fuel filter fitting requiring removal tool (I have 3 sets!) but was not able to remove the fuel filter as the fitting were previously damaged before I bought the X.
While forcing I tore the Teflon/plastic fuel line before the filter, then I had to go to a mechanic who replaced with another cars "housing and filter" but left a kink in the supply pipe.
Every time the X is parked long, eg overnight it requires two cranks (pardon the pun), or attempts to start my X. After over 6 months there is also a starter motor sequel developing now. Similar noise to when the belt slips of old age.
He dropped the fuel tank and lines to replace with another cars line and filter in that area. Also now a few months after the fix, the gauge has started to show less then zero (even when full) and is erratic but am not sure if it has fixed itself after I disconnect the battery and the connection for the wires before the tank. The Haynes manual had a different picture from mine to test for ohms.
Any ideas on a step by step process to remedy the faults? Do you think the kink in the non original line and filter are causing the hard starting and is there a common make car that I can ask to redo. I am in south Africa so parts are hard to get.
ravenflight
Mar 29, 2022 01:13 PM
big greeney
Sep 21, 2011 05:59 PM
jawewa
Sep 10, 2007 10:52 PM
firestorm
Jun 20, 2007 08:33 AM
firestorm
Jun 15, 2007 10:29 AM
