need help 2005 ford explorer
Old May 28, 2016 | 07:25 PM
Waugh2005's Avatar
Default need help 2005 ford explorer
I come home from work explorer was running fine, went back out and hour later to run to store vehicle is acting all sorts of crazy.
Symptoms :
Missing will barely run
White smoke
Oil at bottom of motor on driver side
OIL leaking from muffler
Motor knocking/ticking
Please help what could be wrong?
Old May 29, 2016 | 06:58 AM
You might check the oil level to see if it ran out of oil in which case serious damage may have been done to the engine. With oil coming out of the exhaust system, it may be too late to save the engine.
Old May 29, 2016 | 07:52 AM
Waugh2005's Avatar
It has oil in it we never run it low on oil....
Old May 29, 2016 | 10:24 AM
Did you just purchase fuel on the way home?
Have seen symptoms like these when diesel fuel was put into gas engine vehicle.
Old May 29, 2016 | 10:25 AM
Waugh2005's Avatar
Yes I did
Old May 29, 2016 | 01:02 PM
Was the pump handle Green, which could indicate diesel fuel. If it was diesel fuel , no big deal. The fuel lines should be purged out, the tank emptied and fuel filter replaced. The spark plugs should be removed and cleaned a little. You probably would only need to remove some of the plugs just so it will try to run on a couple cyls and flush the diesel fuel out. This was a common problem with large trucks that had gas engines and people assumed they were diesels and pumped diesel fuel into the tank.
Lets hope that's all that happened here.
ennis1974
Oct 22, 2012 04:51 PM
goiou
May 16, 2009 10:40 AM
sleever
Feb 5, 2009 06:10 PM
soccersees
Aug 23, 2007 09:53 PM
oldschool1
North East
47
Jan 13, 2006 04:25 AM
