Fuel gauge
Old Jan 1, 2006 | 10:48 AM
lat1967's Avatar
Default Fuel gauge
I replaced the fuel sending unit on my 92 explorer two months ago....the fuel gauge was working fine. I did not have to undo the ground strap.
Today, I went out (with 1/4 tank of gas) and the fuel gauge went past the F (full) mark.
So, I filled the tank, drove for a while and the guage seems to still have a problem.
Has anyone had this problem? What did you do to correct the fuel gauge?
Thanks.
Old Jan 1, 2006 | 10:51 AM
lat1967's Avatar
Default RE: Fuel gauge
My 92 Explorer seems to run rough while in drive when stopped or a in park.
How can I determine if there is a vacum leak causing this?
Thanks
Old Feb 10, 2006 | 08:30 PM
jstubleski's Avatar
I am having problems with my 03 explorer fuel gauge. I filled up the tank and it went to 1/2 full and over the next 2 days eventually got up to full. I took it to the dealership and they said there was nothing they could due. They claim that the Sulfer levels in gasoline have been relaxed and now something is getting messed up in the fuel sending gauge. I am not sure if I buy that reason or not but not sure how to fix it.
Old Feb 17, 2006 | 01:02 PM
cngizbleevng's Avatar
That is EXACTLY the problem i'm having with my gauge!!! I just bought the XLT 2 days ago--it is also an '03. I wonder if there is a recall or TSB for it.
ORIGINAL: jstubleski
Old May 3, 2006 | 05:25 PM
CMS's Avatar
CMS
My '02 Explorer is having the same problem with the fuel quantity indication. When it's on 1/2 full and the tank is filled, it takes a couple of days for the gage to read Full. My dealership said there is nothing they could do, but the service manager said he had the same problem with his his Explorer and fixed it by adding Fuel System cleaner to two consecutive tanks of gas. He said the problem then went away.
I have added two bottles of Valvoline Max Life fuel system cleaner, and the problem seems to have fixed itself. Hope this helps. P.S, I think Ford should issue a SB on this because Fords seem to be especially prone this problem.. I have a Dodge Dakota that uses the same gas and no problems whatsoever.
Old May 4, 2006 | 09:16 AM
Joe B's Avatar
I had the same problem.
Try turning the truck off( no listening to the radio on acc) or taking the key out of the ignition on fillup.
Works for me.
Old May 4, 2006 | 01:52 PM
CMS's Avatar
CMS
I found that there is a TSB out on this problem. It is TSB# 18121. date: 9/1/2004
I don't have access to the TSBs, but maybe somebody that does , can tell us what the recommended fix is.
Old May 28, 2006 | 11:16 AM
DuaneJsachMO's Avatar
hi guys i have a problem too. my real name is alexi and im greek! i put an air fuel mixture gauge in my xr6 falcon and my is not any faster! how do i fix this problem!
Old Jun 1, 2006 | 10:20 PM
TK's Avatar
TK
this has happened to me with 04 I have -I ahve switched gas grades and it has stopped and it seems to be working fine, maybe try using a gas cleaner and see if that helps.
mowman
Dec 5, 2005 11:05 PM
nss8425
Oct 26, 2005 06:11 PM
spicer60
Oct 25, 2005 08:38 PM
PFHunter
Oct 8, 2005 07:54 PM
