Hood latch,
Old Jun 2, 2013 | 12:19 PM
lillieIII's Avatar
Default Hood latch,
Going to install a new hood latch cable, last time I Installed one I had problems with the latch being hard to pull. I ended up breaking the plastic pull handle. Any hints as to stop this from happening again. the latch itself is fine and works excellently.
Old Jun 2, 2013 | 03:57 PM
If you can, make sure the cable is lubricated between the insert and the casing.
Make sure there are no sharp bends when routing the cable. Don't overtighten any hold downs for the casing.
Old Jun 2, 2013 | 05:07 PM
primem's Avatar
make sure the hood bump stops are not adjusted to tight. If they put to much upward pressure on the hood with it latched...the cable will be hard to pull to release the hood.
Old Jun 5, 2013 | 07:32 PM
lillieIII's Avatar
thank you, it was the hood bump stops were in need of adjustment, something I should been aware of!
rdlouhy
Feb 3, 2008 02:03 PM
tailgate68
Nov 14, 2007 11:43 AM
tailgate68
Nov 12, 2007 07:34 AM
egm
May 20, 2007 12:09 PM
Irish
Jan 21, 2007 06:05 PM
