How to change fuel filter? - 2003 explorer
32,000 miles on my 2003 Explorer and I want to change the fuel filter. I found the filter hidden behind a shield and I see that there are two styles of fittings. One looks like the type where a special tool is inserted around the tubing and into the fitting. The other two fittings look like there is some sort of red plastic keeper and I have no idea of what to do or what tool to use. Can anyone describe the tools and how they are used?
Thanks, Bob
Thanks, Bob
i know that if i didnt have a hoist to do this job on i wouldnt do it never mind you better make sure you dont break those clips or you will be buying a line to go with your fuel filter...
Got the tool for one end - no problem, got a Chilton manual with detailed procedures and pictures for the two clips on other end - no problem. Oh, and I do have hoist in my garage which does make the job much easier.
Thanks for the responses, Bob
cervin
Aug 14, 2007 11:21 AM
cervin
Aug 10, 2007 08:44 PM
dee004
May 8, 2007 08:04 PM
