how do i turn off the driver side ding when the key is not in the ignition???
i have a 97 ford explorer eddie baure edition and when my key is not in the ignition there is a noise that sounds like the key is in the ignition. how do i turn that off?!?!?!??? i know where it is coming from and i cant just unplug somthing or cut a wire to turn it off cause it comes from one of the computers in the dash. so if any ine out there knows if there is a combination on how to turn it off or somthin, cause it anoys me. cause i keep thinkin the key is in the ignition. thanx
You should be able to pull the ignition lockset out,, and on the shoulder of the casting where the lockset slides into is a small plastic black (usually)clipconnecter that holds a brass 'tang' for grounding the 'key in ignition' chime circuit.. You won't have, or shouldn't have any key warning with the connector/tang 'slid off' and tapped/tucked over to the side of the ignition..Don't cut the wire.. To remove the lockset,, turn the key to the ON position,,then insert a small punch ect in the access hole on the 'bottom' column cover.. Push in slightly and pull the lockset out.. To remove the black plastic connector you'll need to seperate/lift the column cover pieces/sections..
There are five warning chimes and lamps thatthe GEM/CTM (Generic Electronic Module/Central Timer Module) control,, headlights operating without the ignition on (chime only), door ajar (chime and lamp), key-in-ignition (chime only), and driver seat belt warning (chime and lamp). Here's a list of the their functions.. Could be a module issue, but worth a look at the ignition key imput to the GEM/CTM..
Audible Warnings are:
1.Warning Condition
2.Lamp Duration
3.Audible Duration
4.Audible Output
Safety Belt
60 Seconds
6 Seconds
Chime, 60/Min. 740 Hz
Key In Ignition
Continuous
Chime, 120/Min. 740 Hz
Headlamps On
Continuous
Chime, 240/Min. 740 Hz
Door Ajar
Continuous
1 Second
Single Tone, 1000 Hz
Message Center (Tone Request)
1 Second
1.Warning Condition
2.Lamp Duration
3.Audible Duration
4.Audible Output
Safety Belt
60 Seconds
6 Seconds
Key In Ignition
Continuous
Headlamps On
Continuous
Door Ajar
Continuous
1 Second
1 Second
the chime does not get faster when the headlights are on cause i have had several dead batteries cause of that. i dont turn my light on manually any more.
xxtank88xx
Nov 28, 2011 02:13 PM
cinnaman
Aug 9, 2010 05:06 PM
TerryP
Oct 4, 2008 09:42 PM
