Idle on start-up
Old Aug 23, 2006 | 08:49 PM
greesy1's Avatar
Default Idle on start-up
What is the idle suppose to be on start-up? 2004 4.0 liter Ford Explorer. 25,000 miles.
Immediately goes to 1900 then back down. Hot or Cold
No other problems. Just a concern.
Dealer says this is normal, but cannot believe that it's suppose to be this high.
Old Aug 24, 2006 | 06:17 PM
greesy1's Avatar
Default RE: Idle on start-up
After reading this. Idle as in rpm's . Rpm's go to 1900 then idles normally.
Thanks, greesy
Old Aug 24, 2006 | 07:32 PM
94 4x4 ranger's Avatar
1900 is too high.It should be around 800. Is the check engine light on?
Old Aug 24, 2006 | 09:17 PM
greesy1's Avatar
No check engine light. No codes. ECM has been reflashed a few times.
Idle is at 800 once it reaches 1900, it drops to around 800.
As soon as you hit the start position, and the engine starts, it goes to 1900 then drops back
to a normal idle. Warm or Cold.
Olpapa
May 18, 2008 03:22 PM
rippedrob420
May 29, 2007 10:06 PM
6x6man
Apr 30, 2006 03:10 AM
MudWarrior
Mar 5, 2006 03:52 PM
john2windows
Jan 21, 2006 11:47 AM
