Need Advice on 92 Explorer XLT 4.0
Old May 22, 2007 | 09:11 PM
kscsexp's Avatar
Default Need Advice on 92 Explorer XLT 4.0
Recently my wifes 92 has developed some issues. I noticed the other day that there was air in the coolant system because I heard a gurgling sound in the dash (like a water fall). Coolant was low but no signs of fluids mixing. I know in my supra un-purgable air in the system is a sign of a bad head gasket. This explorer has 194k miles on it and a fresh rebuild on the A4LD, like 1 yr ago, about 5k miles. It has a bad lifter as well. I am going to do a block test and a compression test this weekend. How strong is the bottom end on this motor? It does not burn much oil. If I fix the top end will the bottom end blow up? Are head gaskets a common issue? Should I just replace the gaskets and leave it at that? Should I drop a used motor in it? Its my wifes and she does not drive it much, but it needs to be reliable for my kid. What would you do? Thanks
tipit008
Mar 21, 2011 07:31 PM
birdeeshot
Jan 20, 2006 12:28 AM
birdeeshot
birdeeshot
hoppy
Jan 15, 2006 01:47 AM
