p0171 code
Old Sep 15, 2005 | 02:14 AM
macnisas's Avatar
Default p0171 code
My 1999 explorer is registering a fault code p0171( system too lean (bank #1). Any help in what this means would be appreciated.
Old Sep 15, 2005 | 06:54 PM
cctxfish's Avatar
Default RE: p0171 code
If you have the scaner, let us know what the voltage of O2 sensor1 bank1 is.
Old Sep 17, 2005 | 01:35 PM
hockeyhitman69's Avatar
there is a tsb on that code for reprogramming the pcm i worked on one the other day reprogrammed and ok
Old Sep 18, 2005 | 05:15 AM
macnisas's Avatar
Run test and erased code, no problems as of yet. Will be back to ask advice if problem returns. Thank you for responses thus far.
Old Sep 29, 2005 | 04:01 AM
jbwilli's Avatar
#1 fuel injector is clogging. Check electrical physical connection to #1 nozzle. If no help, try a fuel injectore cleaner gas additive. If still no help, change the injector.
If your have TBI, all of this is will not work!
Old Sep 29, 2005 | 08:01 PM
why would you say number one injector is the problem ,is bank one not number one and i have at a ford dealer for 5 years and not seen or heard of that one and i am not talking about the code lol
Old Nov 5, 2005 | 01:29 PM
jbwilli's Avatar
You are exactly correct!? I was answering a question on #1 fuel injector fault. I don't know how it ended up here???
diehardgator1
Dec 11, 2013 07:21 PM
cjohnston2
Dec 22, 2012 11:11 AM
orangeranger2000
May 25, 2010 09:42 PM
argneco
Mar 25, 2009 06:04 PM
rmd8123
Jan 8, 2009 03:18 AM
