Zero power after washer pump replacement
Old Oct 15, 2013 | 09:30 PM
jaypell22's Avatar
Default Zero power after washer pump replacement
I have a 2005 Ford Expedition and today i went to change the cleaner pump for the windshield wipers. I disconnected the positive post then negative. Removed the battery completely, then had to take the battery box out in order to get to the windshield wiper cleaner reservoir. Once i got the reservoir off, i disconnected the hoses and electrical on the pump and installed the new. I put everything back in and went to get in the truck to move it and found that i had zero power. Thought maybe a post was loose or i accidently knocked something loose, so i checked everything several times and still no power. Even had the battery tested and it is perfect. What could be my problem? Could i have possibly blown a main fuse somewhere?
Old Oct 16, 2013 | 06:21 PM
At this point anything is possible. When you were disconnecting the battery cables, did you touch anything to create a spark? We always remove the negative cable first and put it on last to prevent an arc problem.
FordTruckin'
Oct 21, 2011 03:58 PM
bigat
Mar 7, 2008 09:29 PM
lamisun
Oct 28, 2007 10:19 PM
Ham Man
Oct 14, 2007 11:44 AM
427435hp
Jun 3, 2007 07:43 AM
