07 F150 Carrier bearing?
So my carrier bearing slipped out of the rubber on my truck and when I call the auto parts store they tell me that bearing is something they can’t even order and I have to replace the entire driveshaft which is something I’ve had to do twice now for the same reasons in a year. Does anyone know if theirs any way to change it or do I just have to suck it up and fork out
the money for a new drive shaft and what would cause it to keep failing like that? Any help would be greatly appreciated |
Yeah its bull**** on these driveshafts the carrier bearing is not serviceable.
Rock auto has some that are $250 range all the way up to $500 range. If you get a aftermarket driveshaft you should research if the u joints and and carrier bearing are serviceable first. |
(Post 121426)
Rock auto has some that are $250 range all the way up to $500 range. If you get a aftermarket driveshaft you should research if the u joints and and carrier bearing are serviceable first. though since that’s where the last 2 came from, I just don’t know if I did something wrong or if it was faulty parts of if there’s another problem all together |
You've replaced the drive shift twice? Did you use the same one both times from rock auto? What happened to the factory one?
Yeah I have. The original one it was the same thing: the carrier bearing but it didn’t just slip out. The rubber completely blew out and when I changed it, it seemed to be running fine for a while and it did pretty much the same thing a few months later
I’d consider have a shaft assy built at a driveline service with replaceable parts....
(Post 121435)
If you get one piece you don't need a carrier bearing, the off road shop in your area should know a reputable shop who makes custom drive shafts, they are needed for extreme lifts.
(Post 121435)
https://www.drivelinesolutionsohio.com/ |
