07 F150 Carrier bearing?
Old Sep 17, 2020 | 02:27 PM
MKUltra's Avatar
Default 07 F150 Carrier bearing?
So my carrier bearing slipped out of the rubber on my truck and when I call the auto parts store they tell me that bearing is something they can’t even order and I have to replace the entire driveshaft which is something I’ve had to do twice now for the same reasons in a year. Does anyone know if theirs any way to change it or do I just have to suck it up and fork out
the money for a new drive shaft and what would cause it to keep failing like that? Any help would be greatly appreciated
Old Sep 17, 2020 | 03:20 PM
scott.butler4's Avatar
Yeah its bull**** on these driveshafts the carrier bearing is not serviceable.
Rock auto has some that are $250 range all the way up to $500 range.
If you get a aftermarket driveshaft you should research if the u joints and and carrier bearing are serviceable first.
Old Sep 17, 2020 | 06:07 PM
MKUltra's Avatar
yeah that kinda what I was worried about. I’m a little skeptical about getting it from rockauto
though since that’s where the last 2 came from, I just don’t know if I did something wrong or if it was faulty parts of if there’s another problem all together
Old Sep 17, 2020 | 06:31 PM
You've replaced the drive shift twice? Did you use the same one both times from rock auto? What happened to the factory one?
Old Sep 17, 2020 | 07:56 PM
MKUltra's Avatar
Yeah I have. The original one it was the same thing: the carrier bearing but it didn’t just slip out. The rubber completely blew out and when I changed it, it seemed to be running fine for a while and it did pretty much the same thing a few months later
Old Sep 17, 2020 | 09:31 PM
I’d consider have a shaft assy built at a driveline service with replaceable parts....
Old Sep 17, 2020 | 10:19 PM
MKUltra's Avatar
you think maybe if I got someone to machine a 1 piece driveshaft that might eliminate the need for a center support bearing all together, or would that cause other problems? Sorry. I’m not very well versed in this sort of thing
Old Sep 17, 2020 | 11:07 PM
If you get one piece you don't need a carrier bearing, the off road shop in your area should know a reputable shop who makes custom drive shafts, they are needed for extreme lifts.
Old Sep 19, 2020 | 08:49 AM
raski's Avatar
I have used these guys before.
https://www.drivelinesolutionsohio.com/
Thore Kibsgaard
May 4, 2020 09:27 AM
5252
Mar 24, 2020 11:30 AM
kbell015
Dec 10, 2019 11:18 PM
jentner
Jun 17, 2007 11:54 PM
