1985 F150 1/2 ton pickup
Old Apr 8, 2009 | 07:52 PM
Emartinez's Avatar
Default 1985 F150 1/2 ton pickup
4 speed manual, when i turn off the truck, the engine shakes like it wants to stay on.
any ideas?
autozone told me it might be a vaccuum thing, another person told me the timing needs to be adjusted a little bit.
Old Apr 9, 2009 | 12:56 PM
Bullitt94's Avatar
I would check timing first. If you have replaced the cap before it may be slightly off.
Old Apr 9, 2009 | 03:46 PM
Emartinez's Avatar
any idea where the bolt is that holds down the cap so i can turn it?
Old Apr 10, 2009 | 07:55 AM
Bullitt94's Avatar
The base of the distributor kinda looks like a tube with a flange on it that goes into the block. Follow the distributor down to the flange at the block. There will be a bolt there that presses a tab down on the flang to hold the distributor in place (I think you need a 1/2in wrench for it).
fomoko1
Sep 27, 2012 09:54 PM
ponyboi
Aug 17, 2009 01:07 AM
F351
Sep 18, 2006 04:03 AM
IWinULose
Jun 3, 2006 04:49 PM
explorer97
Oct 25, 2005 08:05 PM
