1993 F150 lift/tires
Old Feb 7, 2011 | 11:32 PM
f150isbeast's Avatar
Default 1993 F150 lift/tires
i have a 1993 ff150 2wd completely stock suspension i wanna go with the biggest tires i can with a 2 inch leveling kit.
I wanna know what kind of tires i can put on it with the lift and how big of tires i can put on it without the lift.
im running 235/75/15 <----I know i know dont laugh
Old Feb 8, 2011 | 08:14 AM
Bullitt94's Avatar
You should be able to put 33's on either way. However, you may get some wheel well rubbing if you go too wide with them.
Old Feb 9, 2011 | 09:17 PM
oh ok thats what size i wanted to put... how wide can i fit where it still looks good and can fit my stock 15" rims on them?
Old Feb 12, 2011 | 12:05 PM
Bullitt94's Avatar
You can get 33's to go on 15in rims. As far as the width goes, the norrower the better if you want to prevent rubbing. You can also get wheel spacers or rims with a different offset in the to help out with the rubbing. A lift will do it, too. Keep in mind that the rubbing will only happen when you have the wheel turned all the way.
Old Feb 13, 2011 | 11:13 PM
what would you thin 10.5 width or what? which width would be the best and look the best
Old Feb 14, 2011 | 10:23 AM
Bullitt94's Avatar
Something like that would be good.
Old Feb 16, 2011 | 01:37 PM
do you think that 12.5 is to wide or to much rubbing?
Huk
Mar 7, 2012 12:03 PM
604x4
Mar 2, 2012 10:27 AM
Huk
Mar 1, 2012 07:55 AM
matteson
Jul 9, 2006 08:49 PM
Fountain
Feb 25, 2006 03:05 PM
