1995 F-150
Old Sep 28, 2008 | 04:14 AM
spoolinsrt4's Avatar
Default 1995 F-150
I have a 1995 F-150 with the 302. I am having some problems with it so maybe you guys can help me out. First of all it has to almost completely warm up before you can ever take off and drive, second sometimes it runs great but then sometimes it wont run worth anything sometimes it spits and sputters on acceleration. So far i have tried a new pickup coil, plugs, module, EGR valve, wires, fuel filter, cleaned MAF after changing to a new Air filter,also cleaned the air control valve (? not sure what it is exactly called). The engine light comes on every once and a while then goes right back off. ANy Suggestions???
Old Sep 29, 2008 | 04:30 PM
Bullitt94's Avatar
Default RE: 1995 F-150
Can you give more detail on how it runs and idles?
Old Sep 30, 2008 | 04:17 AM
Use Common Sense's Avatar
As Bullitt94 stated, please provide more details on drivability. Just guessing, it could be fuel pump/pressure, Throttle Position Sensor, or O2 sensor(s). Yes, I've seen bad O2 sensors that do not set any codes, but the CEL will come on and off intermittenly. Just provide more details.
wisconsinwildman
Oct 19, 2007 05:59 AM
tonelaz22
Sep 22, 2007 03:45 PM
area151
Jan 10, 2007 03:18 AM
MATTGOL
Sep 18, 2006 04:14 PM
purplehaze3406
Aug 1, 2004 06:04 PM
