1996 ford f-150 4x4
i have a 1996 ford f-150 4x4 and the driver,s side hub is messed up ! it has the 3 screw hubs with automatic hubs and i want to change them over to manual hubs ! advance gave me a price of $125.00 for the warn hubs and the conversion kit ! i was wondering is all the work to change them over is at the wheels ? i need to get the 4 wheel drive working before winter ! i need your help guys how to change the hubs and the conversion kit ! another thing is that i have the switch on the dash so after i get the hubs in all i do is turn the hubs to lock them in and throw the switch or do i just lock the hubs in and i am in 4 wheel drive ? this is my first 4 wheel drive so i am a little bit handicap when it comes to operating it ! i appreciate your time in helping me out guys !
Here is a exploded view of a hub assembly similar to what you have.
http://www.justanswer.com/uploads/lo...7_232947_1.gif
I think you will need to change parts from the hub cap to the spline spacer. Note the part body assembly.
Since you'll be in there; then would be a good time to also repack the bearings. In which case you'll need a spanner socket, 1/2 drive.
http://www.supermotors.net/getfile/5...e/p8070003.jpg
You might also need another type of spanner socket like this...
http://shop.allfourx4.com.au/WebRoot.../ebay4_047.jpg
The only other special tool(s) needed are a pair of snap ring pliers.
If you've never done this before, might I suggest a repair manual with photos.
And yes, you will still need to throw that switch to go into four wheel drive even with the manual locking hubs.
Hope this is helpful. I'd be happy to attempt to answer any questions you may have in the future. I enjoy "talking" shop.
thanks man ! you been very helpful ! i appreciate you time in helping me ! one more thing if you don,t mind ! the transfer case, ford garage says it takes automatic transmission fluid and i heard from some people it takes 90 weight gear oil ! it has a fill hole and i have to check it ! does it take transmission fluid or gear oil ? thanks again man, you and yours have a great day !
No problem bandit. Glad I could help. Thanx.
Use Motorcraft Mercon ATF in the transfer case.
