1997 F-150 Help!!!
Old Sep 30, 2008 | 05:45 PM
mxer146's Avatar
Default 1997 F-150 Help!!!
I have a 97 f-150 v-8 4.6. It has started missing really bad at an idle. The trouble code says a miss on the #2 cylinder so i replaced the plugs and wires(it did this before and this cured the problem, about 2 years ago). It is still doing this but it is worse now. after we replaced the plugs and wires, we pulled the #2 plug and it was already all black and sooty. brand new plug. I think it might have a blown head gasket right on the #2 cylinder which is causing it not to fire. Any other thoughts or suggestions? Thanks much.
Old Oct 1, 2008 | 12:07 AM
Use Common Sense's Avatar
Default RE: 1997 F-150 Help!!!
You may have a bleeding/leaking fuel injector causing your problem.
scfordowner
Oct 24, 2008 07:57 AM
rangerchaz
Oct 1, 2007 01:44 PM
badandy
May 19, 2006 01:41 AM
c_ferrucci
Nov 4, 2005 10:44 PM
daylynn
Aug 31, 2005 12:53 AM
