1998 Speedometer/Odometer Issue
Old Aug 3, 2019 | 12:35 PM
weby's Avatar
Default 1998 Speedometer/Odometer Issue
So the speedometer and odometer on the cluster of my 1998 F150 is not working. The owner before me had the VSS sensor replaced on top of the rear axle, but that didn't help. All the fuses are good. The volt meter registers voltage at the VSS sensor too. I replaced the entire cluster, but that didn't work either. I also plugged in an OBD II reader and didn't get any reading at all for speed. I need help diagnosing where exactly the problem is. Is there a test I can do that would tell me what is wrong?
4.7L V8, 4R70 transmission.
Thanks,
Will
bbaehr22x
May 17, 2013 08:20 PM
holden
Oct 3, 2010 07:36 AM
whiteface
Jun 25, 2010 01:52 PM
thanos929
May 17, 2007 11:00 AM
JCWIND02
Mar 20, 2007 10:54 PM
