2000 4.2 hard start
Old Feb 26, 2016 | 09:33 AM
  #11
1ArmBandit's Avatar
i was talking about a stethascope..i know about the screwdriver trick to pick up noises but never heard about the hose trick, ill try that first
Old Feb 26, 2016 | 10:30 AM
  #12
Shay_Fox's Avatar
Possible the IMRC (intake manifold runner control) is hung a bit causing the whistle and may help to set the fuel/lean codes. Low engine temp, rich mixture conditions. Most minor vacuum leaks tend to be noticed or develop at idle or just off idle. Again, if you can use a listening device and work around the engine to help point to the whistle origin, might help with a direction. An external vacuum leak should be reasonably easy to pick up.
If the scan tool they used has the capability to access the system PIDS ( parameter information display) they can look and see what the engine running temps are, or, what the PCM see's..
Great information haya. Thanks for sharing this .!!
Old Feb 27, 2016 | 01:30 PM
  #13
greasemark's Avatar
One thing no one's mentioned is the PCV rubber elbow that is always and forever a problem on this engine. It sits directly on the very bottom of the intake and went into a nipple that came out of the intake manifold that is right behind the throttle body; it helps if you take the throttle body off, but I've done so many of these that I can do them in my sleep.
The IMRC wouldn't cause a global leak, since EEC is bitching about problems with both banks. Also, there was a large vaccuum connector on the rr of the intake (right next to where the EGR control valve is) that was a rich area for vacuum leaks due to hoses getting brittle and breaking.
Also, if the intake is ever off, remember to clean the EGR ports out to prevent misfires. This intake on this engine really appreciated that.
Old Feb 27, 2016 | 01:32 PM
  #14
greasemark's Avatar
One other thing: throw a t-stat at it for the P0125. That'll fix that.
Old Feb 27, 2016 | 06:52 PM
  #15
1ArmBandit's Avatar
thanks for the input guys, ill reply with results as soon as i have time to dick with it
Old Mar 10, 2016 | 07:50 AM
  #16
1ArmBandit's Avatar
UPDATE!..so after doing a bit more research not wanting to throw money at it, i determined the easiest and cheapest way to take an eduacated guess was to replace the CHT sensor and reset the pcm...
so i went to my local zone and with the rewards i had on my card i payed 6 bucks for the CHT reset pcm and installed the CHT AND BAM..no more check engine light, all my gauges now work(temp gauge) and my air bag light isnt flashing...purrs like a kitten now
aeropatr82
Feb 17, 2017 06:27 AM
makuloco2000
Oct 22, 2013 09:46 PM
98mkiv
Mar 9, 2007 04:07 PM
Ranger96
Jan 27, 2007 06:18 PM
harkkam
Dec 17, 2006 02:16 AM
