2000 f150 headlights wont shut off
first guess is the switch but it feels normal, have to pull the fuses to shut lights off ?
One way to check this is to remove the headlight sw and unplug the plug from the sw and see what happens. If lights go out=sw , if not now need to look further
pulled the switch lights are still on
I am not clear on your reply. Did you remove the switch and unplug the plug from the switch?
sorry ,, switch completely unplugged
I believe your vehicle had/has Daytime Running Lights, is this so ?
yes it does , it has auto driving lights, but you can turn off with the light switch .
There are 2 relays that are involved with your vehicle's Daytime running lights, The first chance I get I will try to layout where they are.
At this point it could be a problem with the smart stick (sig lt sw) or the relays. |
so i swapped the relays around , all 3 have the same part # , didnt help much, but there is a gray module clipped to the access panel
when i unplug it lights will go out , # Module CBX YL3T-14A597-AA |
Evidently, the problem is within that module.
