2000 f150 headlights wont shut off
Old Nov 5, 2019 | 03:09 PM
fwilliams1's Avatar
Default 2000 f150 headlights wont shut off
first guess is the switch but it feels normal, have to pull the fuses to shut lights off ?
Old Nov 5, 2019 | 05:22 PM
One way to check this is to remove the headlight sw and unplug the plug from the sw and see what happens. If lights go out=sw , if not now need to look further
Old Nov 17, 2019 | 03:02 PM
fwilliams1's Avatar
pulled the switch lights are still on
Old Nov 17, 2019 | 03:35 PM
I am not clear on your reply. Did you remove the switch and unplug the plug from the switch?
Old Nov 17, 2019 | 03:52 PM
fwilliams1's Avatar
sorry ,, switch completely unplugged
Old Nov 17, 2019 | 04:03 PM
I believe your vehicle had/has Daytime Running Lights, is this so ?
Old Nov 17, 2019 | 04:36 PM
fwilliams1's Avatar
yes it does , it has auto driving lights, but you can turn off with the light switch .
Old Nov 18, 2019 | 03:43 AM
There are 2 relays that are involved with your vehicle's Daytime running lights, The first chance I get I will try to layout where they are.
At this point it could be a problem with the smart stick (sig lt sw) or the relays.
Old Nov 29, 2019 | 01:19 PM
fwilliams1's Avatar
so i swapped the relays around , all 3 have the same part # , didnt help much, but there is a gray module clipped to the access panel
when i unplug it lights will go out , #
Module CBX YL3T-14A597-AA
Old Nov 30, 2019 | 01:45 PM
Evidently, the problem is within that module.
pythonwill
Jun 11, 2013 08:42 AM
j.pineda1
Sep 14, 2010 09:19 AM
blueford91
Apr 21, 2008 11:55 AM
Comcast Tim
Mar 26, 2008 07:06 PM
flygirl007
Jul 29, 2007 03:13 PM
