2003 F150 Intermittent starting
Old Feb 14, 2021 | 09:55 AM
Dpbrowne77's Avatar
Default 2003 F150 Intermittent starting
2003 F150 Intermittent Starting. Every once in a while I would turn the key and nothing. Jiggle the shifting arm and the key and still nothing. The next day I can go out and the trucks starts up. Any suggestions?
Old Feb 14, 2021 | 10:30 AM
raski's Avatar
When it acts up, do you hear the starter solenoid click?Do the lights and accessories work? I feel you are dealing with a bad connection. Starting with the battery, engine ground and starter connections, remove and clean up all of them. Don't get fooled and think they "look" good.Afterward if needed, use a voltmeter and go systematically downstream of the battery and see where you have the voltage drop.A rare situation might be an ignition switch, neutral start switch or the safety switch for the clutch pedal if you have a stick.
Old Feb 14, 2021 | 11:17 AM
Dpbrowne77's Avatar
The entire electrical system works when it will not start. No click from the solenoid. Automatic transmission
Mark Crabtree Sr
Oct 22, 2018 09:51 AM
Burnette
Jan 12, 2014 07:17 PM
bleis
Dec 21, 2011 08:34 AM
forthvacav
Jul 3, 2008 05:13 AM
jkshaffer1216
Jun 22, 2004 12:49 PM
