2005 5.4 runs rough exhaust leak?
Old Mar 25, 2021 | 03:38 PM
bigtbasser's Avatar
Default 2005 5.4 runs rough exhaust leak?
Grandson's 5.4 ,2005, missing, running rough using a big amount of fuel. Threw one code, PO 301 then erased it. Found a good size hole in the exhaust before Cad Converter. Would an exhaust leak cause rough running? Removed battery cable to reset computer. Ran find for a while then back to rough. I suppose the computer sees the problem and adjusts to a rich mixture causing the misfires. Any help would be greatly appreciated. Thanks T
Old Mar 25, 2021 | 08:16 PM
scott.butler4's Avatar
Yes a exhaust leak will most definitely cause a vehicle to run rough, since you only have one fault code you should get the exhaust repaired and see if there's any other issues afterwards.
Old Mar 25, 2021 | 08:31 PM
bigtbasser's Avatar
Thanks Scott. Going to go with a temp repair, wrap it, and see if that makes a difference. T
Old Sep 9, 2021 | 06:14 PM
Bill Harlow's Avatar
Will an exhaust leak cause a severe loss in power?
Old Sep 10, 2021 | 06:44 PM
frank Meo's Avatar
If the convertor is plugged it will
Drill a small hole in front of the cat and see if that helps the problem
You can always put a small screw back in it to seal i up
Rodney V
Oct 1, 2020 11:15 AM
afowler25
Aug 31, 2020 04:37 PM
Rodney V
Apr 7, 2020 08:35 PM
ford12989120
Feb 23, 2007 11:08 PM
drw0392
Nov 23, 2006 12:41 PM
