2005 F150 reduced engine power code
Old Jan 10, 2011 | 10:16 PM
danandkim's Avatar
Default 2005 F150 reduced engine power code
why does this seem to go off and then when I restart it goes away for a bit but comes right back, I also have a low RPM hesitation when pulling a hill.
Old Jan 11, 2011 | 06:01 PM
way2old's Avatar
What is the code number you are getting? Need engine size and transmission to help you more.
Old Jan 12, 2011 | 06:01 AM
danandkim's Avatar
Its a 5.4 automatic. I got the reduced engine power figured out but I still have the hesitation. I have actually completely changed tranny because the overdrive module went out ....it was cheaper to install low mile one out of another truck. All plugs and coil packs were changed. Mass air was changed also. I reprogrammed my computer, so you see I have been busy with this problem. Fuel filter has been changed (multiple times over the course of two years with this problem). Please Help!
Old Jan 12, 2011 | 05:57 PM
way2old's Avatar
You might need to have it put on a high end scanner to have the throttle body PIDS checked. The throttle body had the TPS integrated into it along with a few other goodies. It is also possible the cam phasers are not adjusted correctly. They are adjusted by oil pressure.
Old Aug 11, 2011 | 05:49 PM
sspray's Avatar
can you tell me what was causing your reduced engine power light. Mine just flashed on and off. I have a 2007 F150 4.6L v8 automatic
Bobbie Jo Short Thomas
Dec 30, 2013 02:47 PM
dgray02
Mar 11, 2008 07:11 PM
mountainman
Jan 22, 2008 04:43 PM
TNTFowler
Nov 4, 2006 12:59 PM
Mobile AV
Oct 10, 2005 04:48 PM
