-   Ford F-150 (https://www.fordforum.com/forum/ford-f-150-14/)
-   -   2006 F150 5.4l problem (https://www.fordforum.com/forum/ford-f-150-14/2006-f150-5-4l-problem-28703/)
Gregjg Dec 10, 2012 11:58 AM
When I come to a stop and idling, my truck runs really rough (not when I start it). If I put it in neutral and rev the engine above 2000 rpms the idle comes back to normal and I can hardly tell the truck is running. Once I move again and have to stop, the same thing.
I am not getting a check engine light. I have replaced all the plugs and coils yet still getting the same thing. Any Ideas? I have 130,000 miles.
ModestRick Dec 10, 2012 12:06 PM
Have you had the code pulled, you can get a free scan from most auto parts stores and post the code for review. Have you had the throttle plates and IAC motor cleaned? When was the last time the PCV valve was replaced?
Gregjg Dec 10, 2012 12:07 PM
I have hooked up with the obd and there are no errors. check engine light is not on.
way2old Dec 10, 2012 05:20 PM
Unplug the cam phasers to see if the missing goes away.
