2009 4X4 Maintenance
Old Jul 12, 2012 | 05:02 PM
fishfun83's Avatar
Default 2009 4X4 Maintenance
I am considering purchasing a 2008/2009 F150 4x4. I am being told that 4x4's are no problem as long as you do the maintenance. Can someone tell me what maintenance is required and how often it needs to be done. My need for a 4X4 is marginal but it seems like there are as many nice 4x4's out there as there are 2x4's. I really don't want to get into 4x4 problems so if the maintenance is not easy, I will stay away.
Old Jul 12, 2012 | 05:43 PM
Ecoboost3.5's Avatar
I have had more than a few 4x4 fords the only problem has been the front hub bearings have made a littel noise just pull them out and grease them no noise and have made it over 250000miles with 97 f-350 and 02 f-550 both 6spd trans
Old Jul 12, 2012 | 05:52 PM
way2old's Avatar
The 08 or 09 should have an electric switch to engage the 4 wheel drive. Usually a fuse may blow or if you go through a lot of trash, it can disengage wiring. I have an 07 and have not had any issues yet. I have a farm with 60 acres of woods on it and am always driving through junk. You may want to drain and refill the transfer case occasionally and drain anr refill the front axle the same as the rear differential.
Old Jul 13, 2012 | 05:40 AM
fishfun83's Avatar
Thanks for the responses. Sounds like the 4x4 is not a lot of maintenance. Think I will go that route. Thanks again.
Old Jul 13, 2012 | 07:51 AM
paul64's Avatar
Once you go with a 4X4, you know you will NEVER go back.
That's just a fact.
Old Jul 27, 2012 | 09:06 PM
tomcat5's Avatar
Well said brother Paul... well said!
candidguy
Feb 2, 2009 11:22 PM
CESSPOOL
Nov 10, 2007 06:56 PM
4Duh
Oct 30, 2007 12:02 AM
Ronf85
Oct 25, 2007 11:27 AM
quint2
Sep 18, 2007 08:59 PM
