2011 5.0 with trans noise on acceleration?
I traded in the 2006 for a new 2011 5.0 automatic.
When the truck is in gear and the windows open i can hear what sounds like a brake squeek when i gently step on the gas. I know the obvious answer would be to not gently step on the gas but stomp on it but it just doen't sound right. The squeek will continue at the low end of each gear as it shifts if i keep the pedal gently pressed. as the rpm's increase the squeek stops. I'm dropping it off at the dealer tonight for the remote start install which was part of the purchase deal and want to have them look into it. Has anyone had this issue or have any idea what i should tell them to look into? Thank you very much. Hank. |
Update
Originally Posted by cyclonehank
(Post 64125)
Yea, it makes sense that it could be the parking brake hanging up. I know the vehicle is new, but have also heard similar squeaks when a u-joint was running dry.
If you ride the brake a little does the squeak tend to go away? |
(Post 64177)
(Post 64304)
It doesn't go away with the brake pressed. You can't hear it from the passenger side. Maybe it has something to do with the way the 6r80 transmission operates. I know early versions has clutch plate problems but mine doesn't exibit the same symptoms. Doesn't it have some sort of floating yoke where the trive system only engages when you apply the gas pedal? Does anyone have a diagram of the guts that might show how it works? Thanks.
They might have a driveshaft problem that the dealer hasn't heard about.
