2012 Ford F-150 Crank no start after it hit pothole.
2012 Ford F-150 Ecoboost
Driving on a dirt gravel road around 20-30mph, the left side of the truck ran over a rut in the road. It jarred the truck pretty hard. Immediately after, a wrench symbol appeared on the dash. 10-30 seconds later approximately 300-500 feet down the road a Low Oil Pressure warning shows on the dash. We bring the truck to a stop, put it in park, and the engine shuts off by itself. After that, the engine would crank but not start. 2012 FORD F150 V6, 3.5L; DOCH; 24V; DI; Turbo Transmission Automatic Miles: 162585.5 Average Driving Conditions: 50/50 Highway Driving Average Terrain Conditions: Mostly Paved Roads Average Weather Conditions: Susceptible to both Rain and Snow OBD2 CODES: Ford OEM Enhanced Continuous Memory DTCs: P00C6 P025A U0109 U0422 Ford OEM Enhanced KOEO: P025A U0109 U0422 FordSRS: U0155 B11D8 |
Disconnect the low side fuel line from the high pressure pump and see if you have fuel pressure when cranking. You could connect a fuel injector cleaning setup to the low side input of the high pressure pump and see if it starts then.
(Post 127652)
You need to do the testing when the vehicle is not starting.
