2015 F150 navigation
Old Aug 30, 2018 | 08:33 PM
RWestman9202's Avatar
Default 2015 F150 navigation
Good day,
I am new to the F150 and this forum. My 2015 truck has a SD slot and I see eBay has navigation SD cards for sell. When I co to the display and select "Where am I?" the display shows Lat & Long.
Question: Can I purchase one of these SD cards and have navigation capability? If yes, what should I look for?
I will be happy to answer any questions or provide pictures if needed.
Old Sep 4, 2018 | 12:03 AM
Use Common Sense's Avatar
Do you have the factory Navigation System? If so, then you can use the SD Navigation card. Being you have a 2015, if you had the factory Navigation System, it would of came with an SD navigation card with database level A6 (as that was the current database for 2015). The latest Navigation database is A9. The factory Navigation will not work without the SD card in the slot. I ordered my A9 off of ebay and it works perfect. Mind you, some road/destination data/information will be a little behind as things have changed since the database was created and applied to the A9 cards.
r_2016
Oct 28, 2018 12:22 PM
daninzz_p892
Feb 22, 2015 07:42 AM
htw750
Sep 4, 2013 07:46 AM
SamE
Jun 11, 2013 04:29 PM
pajarhead
May 21, 2011 04:03 PM
