4x4 alignment
There are three possibilities that I can think of at the moment.
One is if you excessive toe out the tires will show feather edging and wear on the inside.
Another is excessive negative camber on both wheels.
Also a good check for worn ball joints.
Some "alignment" shops don't carry the offset spacers to do a good alignment on some Fords. You might consider getting it checked by a Ford dealer. They will have the necessary parts.
