94 F-150 Electric draw..
Old Sep 26, 2012 | 01:30 PM
sethk2009's Avatar
Question 94 F-150 Electric draw..
i have a 1994 F-150 xlt with a 302 5.0 manual... Over the past few days the battery has been draining so i undo my pos onmy battery when ever i sit for long periods of time.... if anyone has had this problem or may know a solution to this problem plz email me at truecountryboytn@gmail.com.. or post to this thread.
thank you,
sethk2009
Old Sep 26, 2012 | 04:51 PM
way2old's Avatar
Disconnect the positive battery cable and install a test light or multimeter in between the battery post and cable. If the test light lights, start pulling fuses one at a time until the light goes out. Then find what is on the circuit and you will find your draw. Most test lights will come on with about 30 miliamps going through it. If the light is bright, there is more amperage going through it, so look for something that draws more current. If you use a multimeter, start on the highest amperage setting, usually 10 amps. Then switch down until you get to miliamps. if the draw is over approximately 55 to 60 miliamps, go through the same fuse pulling procedure. be sure not to overload the meter or you will blow an internal fuse.
makuloco2000
Jan 8, 2014 10:18 PM
makuloco2000
Dec 31, 2013 04:14 PM
fordforever
Oct 24, 2010 08:59 PM
plowdriver
Feb 5, 2010 11:10 AM
greuelc
Aug 9, 2007 10:51 PM
