94 Ford Transmission swap
Old Jun 8, 2014 | 11:44 AM
pioneerfan964's Avatar
Question 94 Ford Transmission swap
I have a 94 Ford F-150 w/ 5.8 engine and a bad E-40D transmission. I have available a m5R2 manual transmission from a 1998 Ford F-150 w/4.6 engine. My question is will this transmission work in my vehicle and how much difficulty will I encounter with the swap??? I also have the donor vehicle for spare parts for the swap.
Old Dec 7, 2018 | 09:46 PM
Default Ford F-150 Transmission swap
Can anyone help with this...would like to get truck back on the road...thanks.
Old Dec 8, 2018 | 08:08 AM
It wouldn’t be a direct replacement. Flywheel pattern/imbalance for the two mills etc right out of the gate.
Old Dec 8, 2018 | 11:54 AM
Default 94 Ford transmission swap
Is there any other transmission that wounld be a better fit than the E4OD??
Old Dec 9, 2018 | 09:18 AM
Is/was the goal to swap over to manual?
4x2 or 4x4?
Depending on casting numbers, bellhousing, some of the hardware from 98 may fit from the modular build. But you’d have to source out clutch and flywheel components. As well as address application pieces, mounting, and shaft differences.
E4OD was replaced with the 4R100 which shares build design, just re engineered and updated.
It’s posdible to upgrade to later 4R units with front pump changes, MPLS (range sensor, and solenoid pack swap. But in reality, both are robust units, and the gains aren’t that significant unless you have donor parts and costs are reduced.
If manual is the goal, sourcing out a discounted donor/wreck etc, can be a cost affective path for the needed parts.
If auto is fine, then generally an alike replacement ends up be the most labor and cost affective route. Sometimes a good used can be found for a good deal.. Key would be to find one that’s already been reman, maybe that the engine went south or was wrecked.
Tangerine69
Dec 10, 2012 07:39 PM
pioneerfan964
Feb 11, 2010 07:24 PM
Lukios
Jul 26, 2009 09:30 PM
bmwrocks03
Apr 21, 2008 09:29 PM
sparkeeg
Feb 2, 2008 12:43 PM
