AC and ventalation selector problem
Old Sep 10, 2007 | 09:28 PM
amokay's Avatar
Default AC and ventalation selector problem
I have a 2002 King Rance and a few weeks ago I started having a problem with air conditioning. The air would only blow out through defroster vents. Now the air only blows warm air and it does not sound like the compressor is even engaging. Also, I cannot get the air to blow out any vents except the defroster. It does not matter what temp setting is, or which vent selector switch you push, it will only blow out defroster. Does anyone have suggestions for how to troubleshoot?
Thanks
Old Sep 11, 2007 | 08:17 PM
02greenF150's Avatar
Default RE: AC and ventalation selector problem
Sound like the HVAC Control head is gone bad... Is thecontrol head a vacume controlled contorol head or is it electronic controlled?
Old Sep 11, 2007 | 09:11 PM
amokay's Avatar
How do I determine if it's vaccume or electronic? If it's electronic I assume that I'll have to replace the controller. If it's vaccume, maybe I have cracked hose. Any comments about where to locate the controller would be apprecieated.
Old Sep 21, 2007 | 09:37 PM
jawewa's Avatar
Remove the control head from the dash does it have wires only or vacuum hoses? If it is electronic type it could be the controller or a motor on a blend door in the HVAC unit. The controller is easy to change the blend door ... good luck.[/align]
mdof4
Jul 10, 2010 12:06 PM
nickflorent
Jan 11, 2010 10:22 PM
hookset
Feb 15, 2008 08:11 PM
manctil
Jan 20, 2007 10:06 PM
klhaan
May 15, 2005 10:32 PM
