Anti-freeze
Old Feb 25, 2009 | 09:28 AM
coford's Avatar
Default Anti-freeze
whenever i have the heat on, i have a very strong smell of anti-freeze. i can't seam to find a leak when looking under the hood. it also allows a mist of anit-freeze into the cab. what could be the problem?
Old Feb 26, 2009 | 08:47 AM
Bullitt94's Avatar
Heater core may be failing. Does the windsheild fog up at all?
Old Feb 26, 2009 | 03:35 PM
coford's Avatar
oh yeah, whenever i turn on my heater, it almost looks like my cab is on fire with the way the steam rolls in
Old Feb 26, 2009 | 03:39 PM
Bullitt94's Avatar
That's a bad heater core. Watch your anti-freeze level until you get it fixed.
Old Feb 26, 2009 | 07:39 PM
coford's Avatar
thanks for the info. i'll keep an eye on my level. ill be working on my truck this weekend and i'll be back up with how it all went down
Old Feb 27, 2009 | 09:23 AM
Bullitt94's Avatar
Good luck.
Old Mar 2, 2009 | 01:17 PM
coford's Avatar
well after taking a thorough look into the situation, it seam that there wasn't an actual problem. there was no leaking fluids, i drove it around with the heat on and nothing was going wrong. then the next morning fluid was all over my floor. taking it in tonight to replace the heater core. which doesn't look like it'll be that much fun. removing the complete dash, un-pressurizing my a/c. fun fun fun
Old Mar 2, 2009 | 04:08 PM
Bullitt94's Avatar
That's a typical heater core symptom; not only do you have to replace the heater core, but now you have to clean up anti-freeze inside the cab.
Good luck with the repair and clean-up.
Old Mar 5, 2009 | 10:35 AM
coford's Avatar
so i took my truck to a local auto hobby shop (it's only open for 8 hours a day). i got in there and started talking to the master mechanic about what iam having to do. he strait "recommended" to me that i should now take on this task, that i should just count my losses and take it to a professional. he even told me he would never do another heater core replacement again. so i left, parked my truck in a very good friends drive way and started to rip the dash apart. smooth going at first, you know 700* bolts per plastic piece lol. after about 8-9 hours, and nearly a whole pack of smokes, i have the dash completely off. there was nothing left in but my steering wheel. getting the top off of the heater core housing unit was another core all in it's own. to skip ahead a bit i pulled the old heater core out, put the new one in, hook up the hoses out side, and put the lid back on. i have half the dash back on now and then it started to snow. called it quits for night. 2 days in and i have half of a dash lol
Old Mar 5, 2009 | 03:56 PM
Bullitt94's Avatar
The joys of doing it yourself! At least you'll be able to take pride in a job well done in the end!
