blown up rear end
Old Nov 3, 2006 | 03:30 PM
imboyd's Avatar
Default blown up rear end
Is the S918A rear end a suitable replacement for S829A for my '99 F-150 4x4?
same gear ratio 3.55. but ring gear in the S918A is a 9.75
Old Nov 3, 2006 | 10:43 PM
imboyd's Avatar
Default RE: blown up rear end
OK... let me ask this a different way. The S829A is a 8.8" ring with a 3.55 gear ratio.
The S918A is a 9.75" ring with a 3.55 gear ratio. It is not considered a "direct" replacement, but the S918A has come out of a '99 F-150 like mine. I'm afraid the penalty for a mistake here is a blown up transfer case, which I would like to avoid.
Old Nov 5, 2006 | 02:39 AM
Bullitt94's Avatar
Probably would work as long as you don't beat the living he!! out of your truck.
Old Feb 2, 2007 | 08:38 PM
Andrew beiler's Avatar
i had that problem. i have a 97 f-150 and the vent hoses were pluged badly; and the transfer had a recall the vent hoses were leting large amounts of water enter through the vent. i just ran a vacum hose higher up and made it loop back down with a filter on the end. when the transfer gets hot and cools down it breaths sucking air in when cold and pushing it out when hot. the vent on the rear axle will be pluged probly at the bottom where it goes in to the axle.
hardbalance
Apr 12, 2015 08:48 PM
escaped-eric
Dec 23, 2012 01:33 PM
mr_cb7
May 26, 2012 10:15 PM
CaptJack101
Mar 12, 2008 12:30 AM
ChaostheOmen
May 9, 2005 04:13 PM
