brake master cylinder ?
Old Sep 17, 2006 | 04:11 PM
sonicstyle's Avatar
Default brake master cylinder ?
hello, I was wondering what sensor it is that fried on me...It is infront, on top of the brake master cylinder.?
thanx ernie
Old Sep 17, 2006 | 04:34 PM
94 4x4 ranger's Avatar
Default RE: brake master cylinder ?
[sm=welcomesign.gif]If it is on top of the master it is the brake fluid foat.[hr]This float tell's you when you are low on brake fluid.
Old Sep 18, 2006 | 01:43 AM
What year is your truck?..
If it's up front/top threaded in, it's the brake pressure switch.. It's function is for criuse/speed control deactivation if equipped.. There's a safety recall for a variety of years (94-2002 F-150-550), and models for this switch, for possible overheat/burn problems..
Here's a portion of the recall/service advisory if it pertains to your truck..
SAFETY RECALL 05S28..
SUBJECT: Safety Recall 05S28 - Supplement #9
Certain 1994-1996 Model Year Bronco, 1994-2002 F-150 through F-550, 1997-2002 Expedition, 1998-2002 Navigator, 2002 Blackwood,1994-1996 E-150/250/350, 1996-2002 E-450, 2000-2002 Excursion, and 1998 Explorer and Mountaineer vehicles equipped with Speed Control
Speed Control System Modification
REASON FOR THIS RECALL
The underhood Speed Control Deactivation Switch (SCDS) may overheat, smoke, or burn, which could result in an underhood fire. The potential for a fire exists regardless of whether speed control is being used or the engine is running
Old Sep 18, 2006 | 04:18 PM
sonicstyle's Avatar
yeah it started smoking and really bad, I thought it caught on fire. Ill call the dealer and see what the dealer says about the recall. thanx for the info.
thanx ernie
MercuryMountaineer02
Apr 19, 2007 05:20 AM
treetopp87
Sep 14, 2006 07:41 AM
jcwilliamsjr
Dec 5, 2005 05:35 PM
99 Taurus
Jul 20, 2005 11:15 AM
