Changed ignition now theft light flashing and no start!!
Yup, The wife lost the only set of keys and the remote door lock box for our 2001 F150. I changed the ignition with a new one from Napa. Now the theft light flashes constantly and the truck cranks but will not start.
Please help! |
This is what I believe you may need to do.
You have 2 options; Have a dealer come with programmable keys and the correct scan tool and reprogram your new keys and the vehicle PCM. The other option is to have a locksmith that is capable with the correct scan tool, do the same thing except he will most likely charge a lot less. If there is another option I am not aware of it. |
So there is no procedure like on GM PASS KEY system which you can program a new ignition or ECM to the work together?
You can do certain things like program another key etc. BUT,,,,,,,,,,, you need to have a programmed key to start with. With no key available you have no choice. Might be a good idea to check with a locksmith.
Okay, I thought the two keys which came with the ignition were chipped. I guess like you are stating, I better look up a locksmith.
Thanks, Andy |
