Check Engine Light
Old Oct 2, 2008 | 03:55 PM
dlutz1983's Avatar
Default Check Engine Light
I just had some work done recently and my check engine light wont come on. Is there something that might have come unplugged or needing to be rest. The reason I know this is because I have a misfire in a cylinder.
Old Oct 2, 2008 | 06:20 PM
way2old's Avatar
Default RE: Check Engine Light
What year vehicle? If it is 96 or newer, major parts houses (Autozone-Pep Boys- Advance) will read the codes for free. Post back the EXACT code number and we can help you on the repair.
Old Oct 2, 2008 | 07:29 PM
dlutz1983's Avatar
97 5.4 v8 It gives a code with out the Light coming on. Its a cylinder 4 misfire code.
Old Oct 3, 2008 | 07:21 PM
way2old's Avatar
Be careful replacing the plug. These are bad about breaking off in the head. Does the chweck engine light come on when the key is just turned to the "on" position? If not, check fuses and the cigar lighter. I think they are on the same fuse. If it is OK, the bulb is probably blown.
Old Oct 3, 2008 | 08:24 PM
bsooner1's Avatar
when you say the check money light does not come on do you mean ever (KOEO) or just no code?
93redxlt
Mar 18, 2010 04:44 PM
allensimpson
Jan 10, 2008 09:40 PM
farris1307
Sep 9, 2005 04:59 PM
basketbjones
Aug 30, 2005 10:16 AM
bluemq1
May 16, 2005 08:06 PM
