Check engine light
Old Jun 18, 2006 | 10:53 PM
kerwinq's Avatar
Default Check engine light
My check engine light came on, I figured it was an O2 Sensor so had the code pulled. The code is P0174 which I was told was the O2 Sensor but the place I talked to could not tell me which one. How many O2 sensors are there on a 4.6 and does anyone know which one this code is for?
98 F150 Extended Cab
4.6
Auto
Old Jun 20, 2006 | 12:07 AM
Mulletman's Avatar
Default RE: Check engine light
That code can be set off from a vacuum leak or intake leak. Changing the O2 sensors will not fix it.
Old Aug 14, 2006 | 11:54 PM
tcwilke's Avatar
I have a '98 F150 with a 4.6, and just tackled this problem yesterday. I had codes 171 & 174...fuel sys lean banks 1 & 2. For me, I had a hole in the rubber elbow coming off the PCV valve. I took the neg lead off the battery (to reset the ck eng light), changed out the elbow and have been good for 30 miles so far.
Woo hoo!
Old Aug 15, 2006 | 11:41 PM
94 4x4 ranger's Avatar
My 3.0 94 ranger has 2.
Old Aug 16, 2006 | 12:38 AM
Mulletman's Avatar
Vacuum leaks can be the cause of any Rich/Lean codes.
93redxlt
Mar 18, 2010 04:44 PM
allensimpson
Jan 10, 2008 09:40 PM
farris1307
Sep 9, 2005 04:59 PM
basketbjones
Aug 30, 2005 10:16 AM
bluemq1
May 16, 2005 08:06 PM
