Cranks but will not start
Old Apr 3, 2009 | 08:03 AM
fishfun83's Avatar
Default Cranks but will not start
My wife got into our 5.4 L Expedition this morning and the engine cranks just fine but the engine will not start. Any ideas as to what I can check for? I am going home at lunch to see if I can get it running for her. Thanks,
Old Apr 3, 2009 | 08:41 AM
way2old's Avatar
You need to see if the fuel pump is running for the first 2 seconds the key is in the on (not start) position. Then check all the fuses. Let us know what you find.
Old Apr 3, 2009 | 09:15 AM
fishfun83's Avatar
She called about 30 minutes ago and said she tried it again and it cranked up. Looks like I have an intermittent problem. Oh boy!! Thanks for the info. If I find out anything concrete, I will get back on the forum.
Old Apr 8, 2009 | 04:55 AM
fishfun83's Avatar
Well. Still have the problem. Sometimes it starts and sometimes it does not. Put the OBD on it and found no codes. Still a mystery to me. Any other suggestions to look for? Right now, the only thing I know to do is to disconnect the battery and reconnect to see if I clear a fault somewhere. Shot in the dark.
Old Apr 8, 2009 | 08:26 AM
Bullitt94's Avatar
Is it getting spark when it doesn't start?
Old Apr 9, 2009 | 04:13 AM
fishfun83's Avatar
No. I have not looked for spark because usually when it acts up, I am ready for work and can't get dirty. If it acts up this weekend, I will definitely do what you recommend. Wish there was an easy way to check for spark. Removing the coil over plug is a bit of a pain but not impossible for the front 2.
mlrs3116
Dec 10, 2013 05:01 AM
kinkehee
Jan 15, 2011 08:09 PM
ynwia
Nov 4, 2010 05:04 PM
gf150
Feb 14, 2010 09:51 AM
iownslaves
Apr 1, 2008 06:03 PM
