2000 F350 7.3 cranks but doesn't start-start
Old Mar 31, 2008 | 06:26 PM
iownslaves's Avatar
Default 2000 F350 7.3 cranks but doesn't start-start
Hi Guys,
New member here. Just purchased a used 2000 F350 diesel (100K miles). I got it from an auction block and this is my first time with diesels. I tried starting the car up but it just cranks ( i waited until the message on the car dashboard says it's okay to start). While I am starting it, the meters (gas, power, oil) on the dashboard goes straight to L instead where they were.
It has new batteries (two) and a new fuel filter. The car has been primed and bleed (didn't seal the fuel filter cap all the way so it started leaking). When I took it to my mechanic, he said that the car starts but then there is fire (badazz but bad) when he starts it up so it's afterfiring. He said I need a new engine. Are there any ideas on what I should do/look for? I am thinking an intake valve is staying open the entire time. I am going to go and look at it to see if there is a check engine light or anything crazy on the dashboard.
Thanks in advance,
Terry T.
Old Apr 1, 2008 | 06:03 PM
specwar64's Avatar
Default RE: 2000 F350 7.3 cranks but doesn't start-start
Hmm lets see here. If your 7.3 is cranking but not starting one of the problems could be a camshaft position sensor (camps). Not too hard of a fix if you can get underneath the truck far enough to get behind the crankshaft pulley. you will need a 10mm wrench and a flat bladed screwdriver to remove it. It sits on the passenger side behind the pulley at about 10-oclock or so. remove it with the wrench and remove the wiring connector then just install the new one in the reverse order. That MAY(and i say may) be the problem.The part is about 110.00 dollars or so at ford but buy 2 and keep the other and the wrench & screwdriver in the glove box because when they go,they go with no warning usually and usually while u r on the road. When it goes the truck just stops running.Hope that helps you somewhat.
micsan
Mar 9, 2025 10:12 AM
rkirk
Dec 14, 2007 10:18 AM
rkirk
Dec 13, 2007 10:36 PM
krobman
Nov 29, 2006 04:09 PM
HERE
Nov 25, 2005 12:52 PM
