Door Gap Adjustment?
Old May 8, 2018 | 04:29 PM
ddoiron's Avatar
Question Door Gap Adjustment?
Hey Guys,
I messed up "fixing" the cab corner on my old 1987 F150.
I rebuilt the cab corner and welded in the patch panel.
But I seem to have gotten the fit about 1/8 of an in off...
Now that I just finished the new paint job and all the body work, I just put the door back on to find this...
https://i.imgur.com/kr3XeYE.jpg
https://i.imgur.com/FGCA9vl.jpg
I am hoping against hope that there is some magical technique to be able to move the bottom hinge 1/8" forward so that my door can close properly.
There is no way I am starting that cab corner again... so what are my options?
thanks,
Old May 9, 2018 | 10:34 AM
Looking at your pics, the door gap gets progressively tighter from top to bottom, top gap being slightly large/wide, so the lower hinge needs to be moved forward ( as long it’s adjustment doesn't then crowd the top forward gap)
If the lower hinge reaches its adjust limits and the vert top/side gap is still wide, adjust the top hinge backwards closing in the gap and it will in turn widen the lower a bit. It may take a combo of both hinges, and if crowding the door in the upper/lower gaps, some vertical movement may be needed so there’s no pinch points.
Hinges are/were checked and no play?
If the door/s drop when opened, or can be lifted up/down at the rear of the door, check the hinge pins/bushings for wear. If worn excessive, hinge adjustment becomes a problem, and/ or may not be able to fully adjust the door.
Are the fenders off?
If horizontal-forward adjustment is maxed out due to patch/cab work, , the hinge body bolt holes can be elongated a bit to add a tad more room. But as a last resort...
Old May 9, 2018 | 10:48 AM
ddoiron's Avatar
Hi Hayapower,
Thanks for the reply! your comments give me hope!
I dont see any way to adjust the hinges at all.
do you have a diagram or picture that could help point me in the right direction?
Old May 9, 2018 | 11:24 AM
Looking at the hinge body, where it extends into the cowl/fender, each hinge should have 3 bolts attaching them. But straight off, make sure all the pins and bushings are tight, if not, the door will sage and depending on which hinge, can change normal gaps.....
searchlight4759
Oct 22, 2015 08:19 PM
SydVacant
Mar 30, 2011 05:39 PM
daveranger
May 24, 2007 01:05 PM
SloWnLoW
Mar 12, 2007 08:47 PM
boomerfocus
Sep 24, 2006 08:56 PM
