Driver side upper tie rod end rubbing frame?
Old Jul 10, 2006 | 12:10 AM
prestigeplumb.661's Avatar
Default Driver side upper tie rod end rubbing frame?
I purchased a 03 F-150 4.6L 2wd crew cab and noticed the driver side upper tie rod end is hitting the frame. It came with a small fabtech lift including upper control arms. The idler arm has a little movement in it when both tires are off the ground and you move the tire's right to left. The camber adjustments for the upper control arms are in different settings. Would that have any thing to do with this? Any info would be appreciated. thanks!
Old Feb 15, 2020 | 10:29 PM
Flyboy714's Avatar
Default My are rubbing on both side
Minor rubbing on both sides bought new idler arm and still does not fit has a c St upper control arm and Bilstein shocks cannot get new idler arm installed
Blackknight
Jul 14, 2019 03:38 PM
WildHammer
May 29, 2018 04:27 PM
fogosfishin
Aug 3, 2017 08:57 PM
mcasdorph
Sep 19, 2013 09:46 AM
shel67
Oct 13, 2010 05:32 PM
