F-150 dead cylinder
Old Feb 27, 2012 | 03:15 PM
SMCDonald93's Avatar
Default F-150 dead cylinder
i have a 92 Ford F-150 5.0L. i have replaced spark plugs. and spark plug wires. also the fuel pump and distributor cap. the engine shakes and leaks oil at the dipstick and into the air filter. i know that the 8th cylinder is dead. it gets oil on the spark plug and the ignition tip is black. how do i fix the cylinder?
Old Feb 29, 2012 | 09:05 AM
Bullitt94's Avatar
It depends on what is causing the cylinder to be dead. It could be a warped head, bad valve, bad valve seal, head gasket, bad piston rings, etc., etc., etc.
You will need to determine what is causing it first.
wakeyep
Sep 4, 2013 06:25 PM
redfalcon
Nov 17, 2012 06:02 AM
strandolous
Jan 5, 2010 12:59 AM
rnpalmer2435
Jun 14, 2007 12:48 PM
stoplightcommando
May 1, 2007 03:39 AM
