Sponsored by:
Sponsored by:
CV shaft spinning with Tire in 2 wheel drive
Old 03-15-2018, 06:45 PM
Mlittle7's Avatar
Default CV shaft spinning with Tire in 2 wheel drive
Any help is much appreciated I have a 08 F150 4.6 4 x 4 got stuck in the mud a couple weeks ago then they're grinding started happen in my driver side we'll figure it out it was the actuator replaced both sides no I jack the front end up with the truck running into wheel drive the CV shaft spin when I spin the tire pulled the vacuum lines from the actuator I'm getting about 20 pounds of vacuum this happens on driver and passenger side 20 lb of vacuum when you spend either Tire CV shaft spin with the tire what do I do
Harburmaster
02-16-2009 09:12 PM
CaptJack101
03-12-2008 12:30 AM
broncky
10-08-2007 07:59 PM
broncky
10-08-2007 07:59 PM
LARGOBRONCO
08-23-2005 10:35 AM
Quick Reply: CV shaft spinning with Tire in 2 wheel drive
