f150 4.2l p0302 code only
Old Jun 2, 2012 | 09:53 AM
scotttss's Avatar
Angry f150 4.2l p0302 code only
replaced coil pack plugs wires all from ford still missfire on cyl 2 only drives fine when od is off , but when shifts to od missfire is more pressent and then it is windy out side.. HELP
Old Jun 4, 2012 | 05:11 PM
bluewind's Avatar
But clearing the code doesn't fix the problem.
The misfire may not be caused by a bad ignition part it could also be a fuel injector, or a compression issue or deposits on the valves and the head and so on.
I would listen to the fuel injectors with a stethoscope or something. I would run a fuel system cleaner like "Techron" and I would look at the Throttle body and the EGR system.
Good luck
Tuarus_2000
Jul 11, 2014 06:11 AM
readcit
Dec 12, 2010 11:27 AM
Ziptrav
Apr 12, 2010 06:15 PM
exp97
Jan 9, 2008 09:48 PM
pswhitehouse
Jan 30, 2006 05:10 PM
