F150 4X4 Inoperative and Noisey
Old Feb 2, 2014 | 03:18 PM
makuloco2000's Avatar
Default F150 4X4 Inoperative and Noisey
These are starting to creep up again with the cold wet weather and of course when you need it most your 4x4 doesn't work. It all starts with the vacuum solenoid up on the firewall and goes downhill from there. Even if you don't have this issue yet I explain why you should change the solenoid and save yourself from a costly vacuum hub replacement down the road. I also show you how to replace the vacuum hub (IWE) if yours is already damaged.
makuloco2000
Nov 7, 2014 04:04 AM
makuloco2000
Feb 2, 2014 06:56 PM
makuloco2000
Sep 19, 2013 11:12 PM
jfed1020
Jul 7, 2012 02:08 PM
acit_marcl
Dec 16, 2006 07:03 PM
