ford body swap
Old Jun 20, 2013 | 09:15 PM
mirandaneon's Avatar
Default ford body swap
ok i have a 94 f150 frame (reg cab 8ft bed)and i am wanting to know what i can fit on it. i have a 88 bronco body, and thats waht i would really want to do but either that or crew cab/extended cab. just looking for what the easiest swap?
Old Jul 3, 2013 | 06:12 AM
GilbertF's Avatar
Hi Mirandaneon,
There are many complete system designed for f150! There are design frame mounts to attach the motor plates (front and mid plates) to the frame in the easiest, most effective way for the enthusiast doing the swap himself. I also recommend a dual lateral engine movement limiter system, and include them with complete stage 3 kits! These are the same essential components used on many dragsters, roadsters, and serious door slammers.
Use a full swap kit for full part cooperation:
Install into vehicle with the headers on
Install with ~2" k member spacers to tuck under a stock hood
Install with the radiator out to reduce damage
Install with using stock stang two bolt mount
Stock suspension in front will work fine
Install with trans attached to motor
Attach steering linkage after installing the motor
reomccoy
May 9, 2012 04:23 AM
Ranchertim
Nov 28, 2011 06:24 PM
WV-F150-4.2L
Mar 16, 2011 06:34 PM
toddr1651
Sep 11, 2010 06:44 PM
tdf
Jun 5, 2007 04:01 PM
